  • 275 Vote(s) - 2.67 Average
Motorlift 5000 with bad memory
It sounds like either the range is dropping heavily or the logic board has completely gone. There are 2 options.
1. Replace the logic board for the system (you'll need to find out which frequency your remotes are operating on)
2. Hard wire an additional receiver onto the back of the motor using the 3 terminals which are numbered. This will allow you to use newer remotes which will be more readily available in the future. i believe the 4335E will be discontinued in the near future, and if its the 4185E then this has already been discontinued and are no longer available.
Hope this helps!
(02-03-2014, 01:55 PM)71MGB Wrote: Hi, We have a Chamberlain Motorlift 5000 garage door opener that has worked faultlessly for a long time but recently it has not been responding to the remotes sometimes.
If I go through the procedure for setting the remote to the door unit it works for a day or so then seems to forget it and have to set it up again.
Same thing happens with both remotes and have put new batteries in both of them.
Anyone got any ideas ?
Motorlift 5000 with bad memory - by 71MGB - 02-03-2014, 01:55 PM
RE: Motorlift 5000 with bad memory - by Blakey111 - 13-03-2014, 12:01 PM
RE: Motorlift 5000 with bad memory - by 71MGB - 13-03-2014, 12:25 PM
  Motorlift ML850 Reverses on close. LED flashes 11 (!) times. DJBenz 2 27,559 19-01-2016, 07:10 PM
Last Post: DJBenz
  MotorLift ML700 or 850 blows plug fuses olliecat82 2 17,691 20-11-2015, 07:20 PM
Last Post: olliecat82
  Chamberlain MotorLift 5000 Garage Door Opener secash 1 22,342 27-01-2011, 05:55 PM
Last Post: Mark
  motorlift ML 859GB sparkymike 1 14,199 29-06-2010, 04:45 PM
Last Post: Mark
  Where to buy Motorlift Garage Door Openers easygates 0 12,973 13-01-2010, 12:04 PM
  chanberlain motorlift 5000 1 17,131 20-10-2009, 11:01 AM
Last Post: malito100
  MotorLift Garage Door Openers 1 16,962 28-08-2009, 04:02 PM
