  • 314 Vote(s) - 2.81 Average
Gate closing but not opening
Kindest Regards,
Dave
Dave Blake
Gate closing but not opening - by CAROL - 11-06-2014, 11:17 PM
RE: Gate closing but not opening - by Blakey111 - 12-06-2014, 09:26 AM
RE: Gate closing but not opening - by CAROL - 12-06-2014, 10:58 PM
RE: Gate closing but not opening - by CAROL - 14-06-2014, 08:47 PM
  BFT Gate Motor - Not working elyoussef.ali 1 6,207 11-09-2025, 10:15 AM
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 1,905 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 101,960 21-07-2025, 06:54 AM
Last Post: jojo351
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 3,968 03-02-2025, 12:24 PM
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,100 15-10-2024, 10:37 AM
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,660 17-07-2024, 02:24 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 11,512 14-06-2024, 12:12 PM
  Gate radio receiver not working Zhymke 0 2,963 23-05-2024, 06:35 PM
Last Post: Zhymke
  Gate wont close issue MR_ROBOT 3 16,880 11-04-2024, 08:08 AM
