  • 186 Vote(s) - 2.77 Average
MC824H NIce blowing fuses
Hello Andy,
The MC824H ELS output should be 12VAC, if your measuring on DC this will give you different readings,
are you taking these readings with nothing connected?
(18-11-2014, 12:45 PM)Andy-can Wrote: Hello
I have an Toona 5024 controlled by a NICE mc824H. Recently it seems the electrical lock on the ELS output short circuited and blew the 2.0 Amp fuse on the board.
After replacing the lock it functioned for two openings and then the new lock also short circuited. On checking the control unit it seems it had lost ist setting and set the ELS output as a courtesy light.
On measuring the output of the ELS (no load it showed 26 volts DC constant.
I reset the parameters back to ELS and now when testing again no load I get.
when gate open is pressed.
A brief reading of 26 V dc less then a second but also an AC reading of 24 to 26 volts for 3 ish seconds. this is no load.
Is this normal should there be a brief dc pulse and will an AC output show 26 with no load. the lock is rated at 8 to 12V ac ( as per manual specs)
Strikes me as a not ideal design to allow one output to generate such different voltages.
One more questions, is the circuit diagram available for the MC824H control unit?
if this was available I could trouble shoot at the circuit level ?
MC824H NIce blowing fuses - by Andy-can - 18-11-2014, 12:45 PM
RE: MC824H NIce blowing fuses - by Sav - 27-11-2014, 01:10 PM
RE: MC824H NIce blowing fuses - by Andy-can - 01-12-2014, 05:08 PM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 30 59,049 03-12-2025, 04:18 PM
Last Post: StefanP
Last Post: engrbhadz
  Program a 3rd party remote to Nice Robus N600 P100D 4 8,748 13-05-2024, 03:36 PM
  Nice MC824H gate stuck open Markp80 1 5,736 13-05-2024, 02:32 PM
  Disable Open hold On NICE NC824 paul@blxnetworks.co.uk 4 8,674 02-10-2023, 09:20 AM
  Nice Gates not closing StuL 1 7,872 24-08-2023, 01:34 PM
  Nice Moonbus Photocells - Faulty? ddaddy 2 6,605 11-07-2023, 01:33 PM
  Nice HS400 Andruelectricgates 0 2,645 09-06-2023, 09:28 PM
Last Post: Andruelectricgates
  Nice Robus RB100 - Control Board Buttons Not Working sl991 5 11,765 02-12-2022, 02:51 PM
