  • 253 Vote(s) - 2.75 Average
BFT Regal 5 and courtesy lights
#11
(28-01-2015, 07:48 PM)thm Wrote:
(28-01-2015, 12:09 AM)leeturner6 Wrote: Lock outputs on gates usually only pulse for a set amount of seconds so this wouldn't work unless it also pulsed on close then you could use a latched relay, personally I would go with above mentioned independent switch
That's the regular operation of the lock output. However, the "suction-type" => ON option looks like intended for connecting a magnetic lock, where you keep the magnet powered to keep the gate closed. At least, this is what I think the manual describes, despite the ambiguous terms used, and a multimeter could easily prove or disprove that.
I agree on the independent switch,
Also because i do not know what the amp limitation is on these connectors,.
BFT Regal 5 and courtesy lights - by MCLUMA - 15-01-2015, 10:53 PM
RE: BFT Regal 5 and courtesy lights - by MCLUMA - 23-01-2015, 10:45 PM
RE: BFT Regal 5 and courtesy lights - by thm - 23-01-2015, 11:35 PM
RE: BFT Regal 5 and courtesy lights - by MCLUMA - 26-01-2015, 08:46 PM
RE: BFT Regal 5 and courtesy lights - by thm - 27-01-2015, 10:06 AM
RE: BFT Regal 5 and courtesy lights - by MCLUMA - 27-01-2015, 11:02 PM
RE: BFT Regal 5 and courtesy lights - by MCLUMA - 28-01-2015, 12:31 PM
RE: BFT Regal 5 and courtesy lights - by thm - 28-01-2015, 07:48 PM
RE: BFT Regal 5 and courtesy lights - by MCLUMA - 29-01-2015, 09:47 AM
  Lights to gate Bl8999 1 12,369 14-10-2015, 09:07 AM
Last Post: Dino
