  • 399 Vote(s) - 2.79 Average
SUB300, CB11 Photocells problem
Hi All.
Im in the process of tackiling my 1st install of automatic gates, im an electrician and have been asked over the years about installing gates, but i always walked away leaving it to the professionals. But now im feeling brave and have taken on my 1st job, with another 3 in the pipeline. Ive have installed all as according to instructions, but im having a problem with the photocells, the LEDs on the cells are flashing, 1st they werent on and i discovered this was a polarity problem and fixed, now they are flashing, this according to instructions indicates that the photocell disables the control board, i have my 2 cells connected into terminals 24 & 22, i have tried resetting several times but cant get them to remain constant. i have the gates set up and they are opening and closing fine with the key fob,but nothing happens when i cover the photocells either when gates or closing or opening, both cells are mounted at same height and directly opposite each other on piers.
Would appreciate any help on solving this problem.
Thanks.
Paul.
PS could you recommend a good coded/audio intercom to work in con junction with the CB11.
SUB300, CB11 Photocells problem - by oldsparky - 19-11-2008, 07:24 PM
RE: SUB300, CB11 Photocells problem - by Mark - 09-01-2009, 03:18 PM
  CB11 Multiple Keypad support Pigsfoot 1 5,435 12-08-2022, 08:14 AM
  Problem with delay time CB11 milan 2 15,148 04-10-2021, 01:44 AM
Last Post: DesmondVog
  Adding Extra Photocells To CB22 Onoff 0 7,455 06-08-2020, 01:01 AM
Last Post: Onoff
  chamberlain photocells wlehane 3 33,022 02-09-2019, 10:00 AM
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 35,824 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
Exclamation lift master SCS300 - photocells Willow 1 13,062 14-07-2016, 09:16 PM
Last Post: Willow
Exclamation lift master SCS300 - photocells Willow 0 9,687 13-07-2016, 11:19 AM
Last Post: Willow
  LiftMaster SUB300M + CB11 fault jonesy1991 0 12,482 25-01-2016, 02:51 PM
Last Post: jonesy1991
  CB11 controller BrianP 2 17,245 16-09-2015, 08:58 AM
Last Post: Gateguy
  CB22 problem??? Bakota 0 10,797 16-11-2014, 02:25 PM
Last Post: Bakota
