  • 250 Vote(s) - 2.97 Average
BFT P7 Opening Time / Not Completing Stroke
(07-01-2016, 03:20 PM)Sav Wrote: Hello,
From the details provide i believe this could be a problem with the motor itself i.e possibly the hydraulic oil being low. you said you are setting the system up. Is this its first time use or is it a second hand unit? How old are the rams?.
If its a brand new system this could possibly be a geometry problem with the way the arms are mounted on the gate. I don't believe this will be a control panel problem.
The rams are new. The system itself was setup with some different rams which weren't up to the job, so i'm replacing them with hydraulic ones. I haven't attached them to the gates yet so this is purely testing with no load.
The problem seems to be present on both rams but worse on one than the other. The opening stroke is much slower / has less travel than the closing stroke.
I'll double check the oil. I think the other solution is to try and install some limit switches.
Thanks for you help.
RE: BFT P7 Opening Time / Not Completing Stroke - by zootreeves - 07-01-2016, 08:40 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 11,505 14-06-2024, 12:12 PM
  BFT opening problem 8 55,683 08-08-2023, 02:14 PM
  BFT SubR not opening/closing sometimes Jimmyboy4 3 8,474 09-01-2023, 10:29 AM
  BFT Lux 2B FC Motor not opening all the way to stopper jc.34@outlook.com 8 20,271 19-08-2022, 09:30 AM
  Strange opening problem Baz1981 4 88,494 15-07-2019, 08:39 AM
Question Bft Rigel 5 Gates - Sticking when opening dannys1 3 63,334 23-04-2019, 10:11 AM
  BFT A 40 not opening tojo 0 7,581 06-12-2017, 11:29 PM
Last Post: tojo
Question Bft Rigel 5 Gates - Sticking when opening dannys1 3 21,344 23-08-2017, 02:39 PM
Last Post: Access-Control-Ltd
  Strange Gate Opening Issue scottc 5 36,200 09-06-2017, 03:41 PM
Question Gate closing but not opening CAROL 3 34,417 14-06-2014, 08:47 PM
Last Post: CAROL
