  • 237 Vote(s) - 2.97 Average
Motorlift ML850 Reverses on close. LED flashes 11 (!) times.
After 8 years of use, you may find that the white cogs inside the unit are worn and may need replacing. This is usually the symptom shown when the cogs are worn out. You will require taking the cover of the motor and inspecting the cogs.
The replacement parts can be found at the link below.
http://easygates.co.uk/product_info.asp?ProductID=174
RE: Motorlift ML850 Reverses on close. LED flashes 11 (!) times. - by Sav - 19-01-2016, 11:02 AM
  Motor lift ml850 protector system rondickinson@btinternet.com 1 17,675 15-04-2019, 09:34 AM
  ML850 no longer operates rivergo1d 1 26,037 12-04-2018, 04:52 PM
Last Post: Tim
  MotorLift ML700 or 850 blows plug fuses olliecat82 2 17,690 20-11-2015, 07:20 PM
Last Post: olliecat82
  Motorlift 5000 with bad memory 71MGB 2 18,808 13-03-2014, 12:25 PM
Last Post: 71MGB
  remote will open but not close garage door Sharon OWest 4 26,914 01-08-2013, 10:38 AM
Last Post: DJBenz
  ML850 Remotes don't work huckit P 1 23,073 06-01-2012, 09:59 AM
Last Post: Mark
  Chamberlain MotorLift 5000 Garage Door Opener secash 1 22,342 27-01-2011, 05:55 PM
Last Post: Mark
  motorlift ML 859GB sparkymike 1 14,199 29-06-2010, 04:45 PM
Last Post: Mark
  Where to buy Motorlift Garage Door Openers easygates 0 12,973 13-01-2010, 12:04 PM
  ML850. Setting the Limits Brillopad 2 29,720 03-11-2009, 02:49 PM
Last Post: Doorman
