  • 214 Vote(s) - 2.72 Average
Photocell Problem
Hi all,
This is my first post (aside from intro) so please bear with me. I have an issue with electric cantilever style sliding gate. I have a pair of photocells on each side of the gate (to prevent the gate closing on someone when either coming or going). For each pair there is one photocell on the powered side of the gate (where the gate is mounted), and I have another photocell opposite each of these which is battery powered (I'm assuming this is the transmitter?). The problem is as follows:
The gate will not close as one set of cells are "clicking" as if the beam is being broken, but it is not. I have changed the batteries in the "transmitters opposite, but this makes no difference. The red led that indicates the photocell is receiving stays on for about one second, then clicks and the light goes out, then it comes back on and does the same thing over and over again. I took the transmitter off the other side and put it straight up in front of the receiver, and it does exactly the same thing. It picks up the beam, then seems to click as if it has lost it (but I have not moved), then it clicks back on again. I have a video of this, but not too sure where to post it?
To get my gate to close again I have placed a jumper wire across the switch terminals to get the gate to close.
Any ideas? Burnt out relay on the board? Do I need a whole new photocell?
Thanks in advance for any help/suggestions.....
Photocell Problem - by marcoos_1 - 14-02-2016, 02:32 PM
RE: Photocell Problem - by MWJONES - 14-02-2016, 05:18 PM
RE: Photocell Problem - by marcoos_1 - 15-02-2016, 02:10 PM
RE: Photocell Problem - by Jonloach - 28-12-2023, 11:01 PM
RE: Photocell Problem - by JoeF - 04-01-2024, 10:23 AM
  Faac photocell stopped working Zeb Gulickx 2 7,892 28-01-2024, 12:56 PM
Last Post: Zeb Gulickx
  water damage to FAAC photocell Rajab 4 9,220 18-07-2022, 09:00 AM
  Master to slave remote problem Dingerb 0 3,716 24-12-2021, 01:26 PM
Last Post: Dingerb
  Proteco Leader N1 problem Luc Bevers 0 4,211 22-10-2021, 09:57 AM
Last Post: Luc Bevers
  Proteco gates with photocell problem. Shane1 0 4,063 09-10-2021, 07:56 PM
Last Post: Shane1
  BFT ULTRA BT A50 problem cayres 0 4,063 13-04-2021, 08:19 AM
Last Post: cayres
  Beninca RI 6E Problem leonardermo 0 6,293 29-04-2020, 08:45 PM
Last Post: leonardermo
  BFT C130 Photocell Issue labbetts 0 5,858 25-01-2020, 05:01 PM
Last Post: labbetts
  Genius Gate System Problem grasshopper 1 14,610 01-07-2019, 09:39 AM
  Genius JA574 problem jeeter 0 6,605 02-05-2019, 01:13 PM
Last Post: jeeter
