  • 234 Vote(s) - 2.79 Average
Proteco Q36a problems
I have a Proteco Q36a swinging gate controller and I am having some problems.
It seems that the two engines didn´t get any current and so the gates dont open.
I didn´t change any wire and until now it was working fine.
The display on the board shows "--" which is the standby. When I press the remote controller
I can see "-.-" on the display which shows that the board is receiving the signal but then nothing happens.
I have already tested to shorten the 1 & 8 pin and then I can see "Go" on the display and I can hear a tick but the gates didn´t open. After some seconds the display shows "--" again.
While that I have meassured the voltage of the engine1 and engine2 and there is always 0V.
The main power is working fine and has 230V.
I also checked the both fuses which are on the board and both are fine.
Is there anything else that I can test to see if the board is broken?
It would very nice if you can help me.
Thank you in advance for your help.
Best Regards
Daniel
Proteco Q36a problems - by gentle9 - 27-07-2016, 12:07 AM
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,387 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 3,348 19-06-2023, 01:03 PM
Last Post: xCO
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 10,114 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 7,439 12-07-2022, 11:48 AM
  Proteco Q60 - FH error then close after opening Needlerp 1 5,864 24-06-2022, 09:54 AM
  proteco q60a microcontroller program arashkhan 1 5,571 17-06-2022, 01:29 PM
  Proteco Q60 AR ...Fob wont program Shane1 0 3,809 12-01-2022, 08:13 PM
Last Post: Shane1
  Proteco Leader N1 problem Luc Bevers 0 4,207 22-10-2021, 09:57 AM
Last Post: Luc Bevers
  Proteco gates with photocell problem. Shane1 0 4,058 09-10-2021, 07:56 PM
Last Post: Shane1
  Proteco Aster 3 ram fault soother 2 8,472 14-07-2021, 11:58 PM
Last Post: soother
