  • 252 Vote(s) - 2.83 Average
Genius 452/455 Learning Issue
Hi there
I have had a go at carrying out your instructions today.
I held the push button for more than 3 secs and the gate started to open as you said. The next Open A slowed it down and when it touched the end stop I gave it 2 seconds and then gave it another Open A which stopped the gate and the engine.
I waited for 20 seconds and then gave another Open A to start closing the gate again. This did nothing. I had to give it another 3 Open A commands and then the gate started to close. I gave it another Open A to slow it down and then a further Open A to indicate it was closed.
DL10 then went out to indicate that the learning program had stopped.
I powered down and then on again.
I sent an Open A and the gate went through its program and opened, slowed down and then stopped at the plate.
It then never started to close even if I left it for 10 minutes. I had to dis engage it to shut it again.
There seems to be a problem with the learning sequence that is just not quite right to start the closing sequence.
Any help is appreciated.
(18-12-2016, 10:51 PM)Automatic-TC Wrote: hi
hold button untill gate start to open(about 3sec) ,i recomend you to program slow motion about 20 cm from ridged plates ok .
when gate start to opening wait and press shortly open A (about 20 cm from ridged) engine suposed to slow down , when gate hit ridged plate givie it 2 sec and press shortly open A .
Now gate have to close and like before give short press before 20 cm from ridged plate ,engine will slow again and when hit ridged plate give it 2 sec and press shortly open A . thats it .
i hope you have installed 2 ridged plates(open/close) that will prevent your gate engine against failure.
fore give me my english
important - switch power off and on . first signal frome open A suposed move gate to open !!!
if is diferent let me know .
Genius 452/455 Learning Issue - by Robedj - 18-12-2016, 01:50 PM
RE: Genius 452/455 Learning Issue - by Robedj - 18-12-2016, 10:22 PM
RE: Genius 452/455 Learning Issue - by Robedj - 27-12-2016, 05:08 PM
RE: Genius 452/455 Learning Issue - by Robedj - 02-01-2017, 06:44 PM
RE: Genius 452/455 Learning Issue - by Robedj - 03-01-2017, 10:27 AM
RE: Genius 452/455 Learning Issue - by Robedj - 06-02-2017, 09:37 PM
  BFT Demios A600 bAr issue Rohbot15 2 1,893 15-08-2025, 01:41 PM
  BFT Deimos issue erickavo 2 2,854 09-07-2025, 11:34 AM
  Genius JA592 issue fintaneduffy 3 5,551 19-01-2024, 09:58 AM
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 5,781 25-05-2023, 03:55 PM
Last Post: Kaala1
  BFT IGEA BT issue warren5 1 5,592 13-04-2022, 11:49 AM
  Genius Brain 17 Control Board - External Open/Close Signal rhennessysummit 1 8,409 02-05-2021, 09:00 PM
Last Post: soother
  Beninca BOB21m Photo cell issue Rossm1987 1 7,595 02-05-2021, 12:39 PM
Last Post: Rossm1987
  BFT C130 Photocell Issue labbetts 0 5,858 25-01-2020, 05:01 PM
Last Post: labbetts
  BFT DEIMOS BT Programming issue dawoodejaz@hotmail.com 0 6,360 28-11-2019, 12:11 AM
  Genius Gate System Problem grasshopper 1 14,610 01-07-2019, 09:39 AM
