  • 130 Vote(s) - 2.98 Average
I am trying to add a wifi relay to open/close the gate
If you wire across 28 & 30, a momentary pulse would activate the gate to open.
The Rigel 4 is a very basic panel, so no other programming would be required.
(29-05-2017, 09:49 AM)dentalan Wrote: Hello. I have a BFT gate opener (I think it is the LUX model-2 arms) connected to a Rigel 4 control box (It does not have an LCD screen so it is not model 5). It works ok. I used one of the remotes and cabled it to a relay in a way that I can togle the button momentarilly using an application from my PC. So I can open/close the gate from a remote location. It works but I need a more robust solution. I found these wifi realays ( https://www.itead.cc/smart-home/inching-...witch.html ) which can be activated from my android phone. I found that the pins 28 and 29 on the JP5 are for use with a push button. Is that correct? If I connect 28 to COM momentarilly will this open the gate? I am trying to be sure before I test it.
ps: I think it is important. The door works like this: door Closed-->press remote-->door opens --->press remote while door opening---> door stops---> prees again-->the door closes
Thank you
RE: I am trying to add a wifi relay to open/close the gate - by Sav - 30-05-2017, 10:22 AM
  faac gate wont close. stupidlee 5 46,015 08-04-2019, 09:17 AM
  jet 230v swing gate motors!! nashdan99 1 11,293 17-05-2016, 09:41 AM
  H3D Relay wiring whitty1234 5 27,191 31-01-2014, 04:52 PM
