  • 161 Vote(s) - 3.03 Average
Rigel 5 and sub r
Hi Steve,
Thank you for your enquiry, i will post below the manual for the Rigel 5 board which will help with programming and error codes. I would advise you to check the motor output terminals on the board if the motor has come back from testing as not faulty. If you are getting the correct voltage once a command to the gates have been given then i would be checking the capacitors, this can be done by swapping the capacitor from the working motor to the motor that isn't working. If the fault moves from motor to motor then we know that this is the problem. Hope this helps and if you need any more assistance don't hesitate to contact us.
http://manuals.easygates.co.uk/PDF/misc/bft-rigel-5.pdf
Kind regards
Tim
Rigel 5 and sub r - by Stev214 - 20-02-2018, 12:30 PM
RE: Rigel 5 and sub r - by Tim - 28-02-2018, 12:25 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 101,957 21-07-2025, 06:54 AM
Last Post: jojo351
  BFT Rigel 5 Talonfinger 0 2,068 26-03-2025, 12:07 PM
Last Post: Talonfinger
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,356 03-02-2025, 11:29 AM
  BFT Rigel 5 - Phot message robs999 2 4,741 01-11-2024, 11:22 AM
Last Post: robs999
  Stressing over BFT Rigel 6 Help please Vaf888 3 5,020 30-10-2024, 12:54 PM
Last Post: Vaf888
  BFT Rigel 5 issue Adamit 0 2,735 17-05-2024, 10:28 AM
Last Post: Adamit
  Just Got A Rigel 5 and need HELP!!!! rapley 2 17,950 04-05-2024, 12:47 PM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 5,241 04-01-2024, 10:21 AM
  Rigel 6 conections Muttlymoo1979 0 3,760 21-07-2023, 08:52 PM
Last Post: Muttlymoo1979
  Er 10 code on RIGEL 6 control unit Eddiew 1 6,995 05-01-2023, 11:53 AM
