  • 370 Vote(s) - 2.87 Average
LYN300 closing problem
whitegatenorm Wrote:Furhter investigation reveals; with nothing connected to 'close photo' input, the red LED adjacent to that input stays lit even though switch 5 of S1 is set to normally open.
With switch 5 set to normally closed and a wire bridge in 'close photo' input then gates work OK but the close sensor is obviously not functioning. sounds like a main board failure to me but expert opinion would be appreciated.
This sounds like a Photocell problem if the lite goes out with the contacts bridged out.
Double check your connections to the photocell and make sure they are lined up then switch save switch off to see if the lite goes out if it does then switch save back to on.
The circuit needs to learn the saftey circuit by switching the save switch off for 20 second then back on
If this does not cure the problem then you would need new photocells
LYN300 closing problem - by whitegatenorm - 23-12-2008, 05:57 PM
RE: LYN300 closing problem - by whitegatenorm - 26-12-2008, 05:42 PM
RE: LYN300 closing problem - by Mark - 02-01-2009, 02:04 PM
RE: LYN300 closing problem - by whitegatenorm - 04-01-2009, 11:55 AM
RE: LYN300 closing problem - by whitegatenorm - 10-01-2009, 02:50 PM
  Difference: SCS300, LYN300, and LYN400? DevsAd 3 9,224 02-03-2023, 03:12 PM
  Problem with delay time CB11 milan 2 15,151 04-10-2021, 01:44 AM
Last Post: DesmondVog
  Lyn300 lubrication Capricious 5 17,393 08-06-2021, 12:37 PM
Last Post: Capricious
  Sliding gates are opening/closing like someone is going in /out. gandreja 3 14,330 14-04-2020, 01:45 PM
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 35,824 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  CB22 problem??? Bakota 0 10,799 16-11-2014, 02:25 PM
Last Post: Bakota
  Remote problem Nickhh 1 12,236 30-09-2014, 04:48 PM
  liftmaster CB11 hold gate open problem sparkey 5 37,729 13-05-2013, 08:17 AM
Last Post: brucekwilles
  Problem with CB11 Board Michael 1 14,160 08-05-2013, 11:32 AM
Last Post: Mark
  LYN300/400 thermiclance 0 8,973 29-10-2012, 08:58 AM
Last Post: thermiclance
