  • 132 Vote(s) - 3.03 Average
Bft gates (im not technical)
Hi Chris,
Thank you for your enquiry, the click that can be heard when a photocell beam has been broken is a relay that changes from N/O to closed or N/C to open. If the second set of photocells aren't doing this then i would advise you to check the photocells are correctly aligned, then check the voltage to the photocells then a continuity test of the cabling being used back to the control board. In past experiance i would of thought it will be aliment or voltage issue. If this still doesn't fix the problem feel free to contact us again.
Kind Regards
Tim
Bft gates (im not technical) - by chriscovbft - 02-04-2018, 09:56 PM
RE: Bft gates (im not technical) - by Tim - 12-04-2018, 03:52 PM
  FAAC GATES NOT CLOSING Slick19000 0 5,336 21-07-2021, 01:45 PM
Last Post: Slick19000
  Hi All BFT ALTAIR-P gates not closing michaelo76 0 6,867 13-08-2018, 05:47 PM
Last Post: michaelo76
  Just found you my gates are stuck open bomitie 1 10,027 30-04-2018, 01:56 PM
Last Post: Tim
  Failure of Swing Gates to Close Auto A C John 1 11,687 28-09-2016, 09:23 PM
Last Post: MWJONES
Wink Geniss Gates with Genius BRAIN 03 Control Board 4LPS 3 22,279 10-08-2015, 09:31 PM
Last Post: 4LPS
