  • 136 Vote(s) - 2.81 Average
ML850 no longer operates
Thank you for your enquiry, the 5 flash error code refers to a problem with the RPM sensor. It would be hard to say what has caused this without seeing pictures of the system and the problem with the ML850 is that as it is a discontinued operator there aren't many replacement parts left. It would more than likely be a replacement kit you would need as we don't have any stock left of the logic boards and rpm sensors. I will post a link below showing you the operators on our website.
http://www.easygates.co.uk/garage-door-openers.asp
Kind regards
Tim
ML850 no longer operates - by rivergo1d - 03-04-2018, 01:23 PM
RE: ML850 no longer operates - by Tim - 12-04-2018, 04:52 PM
  Motor lift ml850 protector system rondickinson@btinternet.com 1 17,676 15-04-2019, 09:34 AM
  Motorlift ML850 Reverses on close. LED flashes 11 (!) times. DJBenz 2 27,559 19-01-2016, 07:10 PM
Last Post: DJBenz
  ML850 Remotes don't work huckit P 1 23,073 06-01-2012, 09:59 AM
Last Post: Mark
  ML850. Setting the Limits Brillopad 2 29,720 03-11-2009, 02:49 PM
Last Post: Doorman
