  • 59 Vote(s) - 3.03 Average
Motor lift ml850 protector system
(02-01-2019, 05:36 PM)rondickinson@btinternet.com Wrote: I have an ml850 with 770e protector system. Can anyone tell me if there should be lights on both sending and receiving sensor. On mine there is only a green light on sending sensor. When closing the door with the keypad the unit light flashes a few times and the door will only close if keypad Is held until door fully closed.
Hi Ron,
There should be lights shown on both sending and receiving sensor. It is more than likely going to be a wiring problem. Check your connections are not broke.
RE: Motor lift ml850 protector system - by SamA - 15-04-2019, 09:34 AM
  ML850 no longer operates rivergo1d 1 26,032 12-04-2018, 04:52 PM
Last Post: Tim
  Motorlift ML850 Reverses on close. LED flashes 11 (!) times. DJBenz 2 27,555 19-01-2016, 07:10 PM
Last Post: DJBenz
  ML850 Remotes don't work huckit P 1 23,072 06-01-2012, 09:59 AM
Last Post: Mark
  ML850. Setting the Limits Brillopad 2 29,718 03-11-2009, 02:49 PM
Last Post: Doorman
