  • 38 Vote(s) - 2.87 Average
Nice MC424L "hold open" feature
So I took a closer look today and have tried to reproduce the event:
Model: Nice MCA2( not MC424L, as previously stated) so this is the manual https://www.niceforyou.com/sites/default...1.4858.pdf
Operation mode: Condominium - enabled, Automatic Closing - enabled, Close after photo -disabled
3 remote control modules installed:
- 1xthe one that comes in the computer slot - inital module - named (a)
- 2xFLOx2R - named (b,c)
- 1 GSM module (d)
t0: gate is closed
t1: gate receives the open command from any of the inputs (a ->d) - takes about 35s to open
t2: gate is opened - stays open for pause time - of 20s
t3: pause time expires
t4.1: LIGHT(gate light) start flashing 0.2-0.5s
t4.2: GATES stop moving - 45s till close
t5: gates are fully closed
The issue appears:
- if between the time that the LIGHT starts flashing(t4.1)
- and
- the gates start moving(t4.2)
- an open(remote click) command is sent from the (b,c) controllers
- the gate will stop moving
- remainin opened indefinitely as no other controller (b,c,d) can be used as they will only issue open commands(as they issue only OPEN command because of the Condominium setting).
This situation can only be solved:
- if one of the controllers on the initial module is used (a)
- which somehow still accepts just at this step the STEP-BY-STEP command
- this starts closing the gates.
The (a) module works in Condominium the rest of the time, it will only issue OPEN command, and never issue a STOP command.
So the conclusion is that something happens within the first second after the 'pause time' expires, and somehow sets resets the 'pause time' to infinite - looking like a STOP command.
As per your question @JoeF:
- i've checked, no cables are loose, doubled checked
- normally all the leds 1->5 are switched off, I understood this is a power saving feature, but couldn't find it in the book
- after any command 1,2,3 are on
- the OK led blinks once every 1s, and 3x quickly if a command is recieved
- when I issue a command between t4.1 and t4.2 the L5 led blinks once, and then stops, so all L1,2,3,5 are on
It all looks like a 'hold open' command, but one that is not in the manual.
Hope this sheds a bit more light.
Thanks a lot!
Nice MC424L "hold open" feature - by bptra - 01-07-2019, 08:13 AM
RE: Nice MC424L "hold open" feature - by JoeF - 01-07-2019, 08:56 AM
RE: Nice MC424L "hold open" feature - by bptra - 04-07-2019, 02:28 PM
RE: Nice MC424L "hold open" feature - by JoeF - 10-07-2019, 10:38 AM
  Nice Robus closing after photo Nexur 1 7,246 26-08-2025, 01:47 PM
  Nice LFAB occasionally failing open DaveHG 3 9,580 20-08-2025, 01:52 PM
  Nice gates don’t close after the ambient temp is high Howard 2 7,916 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 3,599 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 4,232 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 4,362 09-05-2025, 01:07 PM
  Looking for help with oldschool NICE gate motor gatekeeper 0 4,941 16-02-2025, 05:16 PM
Last Post: gatekeeper
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 3,095 08-02-2025, 07:22 PM
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,410 10-12-2024, 11:29 AM
  Nice MC824H Set Up issue dmrgate 2 7,817 10-12-2024, 10:31 AM
Last Post: dmrgate
