  • 22 Vote(s) - 2.68 Average
Nice transmitters - compatibility
I am in the process of having new gates fitted with a Nice opening mechanism. The installers have offered me ERA ONE remotes, black and white, but on the EasyGates site I found Era INTI remotes that look similar but are more colourful. My question is, are the INTI remotes/transmitters compatible with an ERA ONE receiver? They seem to use the same frequency but I have not seen the INTI transmitters described as a viable replacement for Era Ones.
Thanks in advance!
(29-09-2022, 05:05 PM)Noghar Wrote: I am in the process of having new gates fitted with a Nice opening mechanism. The installers have offered me ERA ONE remotes, black and white, but on the EasyGates site I found Era INTI remotes that look similar but are more colourful. My question is, are the INTI remotes/transmitters compatible with an ERA ONE receiver? They seem to use the same frequency but I have not seen the INTI transmitters described as a viable replacement for Era Ones.
Thanks in advance!
Good Afternoon,
Thank you for your enquiry.
The inti remotes are essentially a smaller version of the ERA ONE remotes. They will be compatible as they are the same coding and frequency.
Kindest Regards,
Thanks in advance!
Good Afternoon,
Kindest Regards,
Thanks, but I received exactly the opposite advice from tech support at Easy Gates, who said the two transmitters were not compatible, and I would need an additional receiver. So now I don't know what to think. I may buy an inti and try it for myself.
" The Inti remote controls cannot work alongside the standard Era One coding fobs I am afraid, the reason for this is that one style of fob uses the O-Code programming and the other Flo coding and therefore cannot work synergistically.
If you are keen to have both styles you could purchase an additional OX2 radio receiver which will allow for the function of both fobs. "
(30-09-2022, 07:46 PM)Noghar Wrote: " The Inti remote controls cannot work alongside the standard Era One coding fobs I am afraid, the reason for this is that one style of fob uses the O-Code programming and the other Flo coding and therefore cannot work synergistically.
thank you for that information.
Just done some more digging. The ERA one remotes can work with the INTI remotes. But the ERA one remotes will need to be programmed in first them the INTI second.
Hope this helps.
Hope this helps.
You are absolutely right. I have just received an INTI and programmed it from the Era One transmitter with no problems at all.
Moreover the INTI is half the size of the Era One and far easier to keep on a keyring.
Thanks for your help. Smile
Hope this helps.
Thank you for your response,
We are glad that we can be of assistance to you.
  Nice Robus closing after photo Nexur 1 386 26-08-2025, 01:47 PM
  Nice LFAB occasionally failing open DaveHG 3 1,924 20-08-2025, 01:52 PM
  Nice gates don’t close after the ambient temp is high Howard 2 1,446 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 1,561 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 2,033 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 2,247 09-05-2025, 01:07 PM
  Looking for help with oldschool NICE gate motor gatekeeper 0 2,888 16-02-2025, 05:16 PM
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 2,195 08-02-2025, 07:22 PM
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 7,023 10-12-2024, 11:29 AM
  Nice MC824H Set Up issue dmrgate 2 5,315 10-12-2024, 10:31 AM
Last Post: dmrgate
