  • 107 Vote(s) - 2.95 Average
Faac 640 query
I moved my query from the introduction section, see is there any more action in the Faac section.  Big Grin
I  recently stripped down an old Faac 640 automatic barrier, rebuilt it including a brand new piston and a new spring for a 7 metre beam.
Electrically it works perfectly but it groans and is very noisy. When closing I have to assist it, by leaning on it.
Note: As it's inside my garage, I only have a 2 metre plank instead of a 7 metre beam installed.
Used genuine Faac oil and level on dipstick is OK.
Bled pistons for air a number of times, spring side when opening, non spring side when closing. (made no difference)
When I put pump in manual operation, the motor runs quietly, and the barrier rises quietly by hand.
My question is when closing against the 7 metre spring does the barrier need the assistance of the 7 metre beam or should the pump overcome the resistance regardless.
Why is it noisy and groaning, I don't recall it being so, when it was last used (long time ago). Is the pump ill ?
Thanks.
This forum has the quietest 1740 members on the internet.
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 2 3,566 01-10-2025, 09:17 PM
Last Post: Adam_k
  Faac 740D, Open further then limit, not closing emiel 1 5,745 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 3,518 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 3,286 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,371 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 2,859 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 8,301 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 6,422 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 7,261 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 6,068 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
